I have a 30+ year old discoloured surface mount cooker control unit. The 13A socket powers my all-gas cooker (clock & ignition), the high current side hasn’t been used for decades but I'm buying a dual fuel cooker (4.4kW) and want to change to a nice new cooker switch.
I have period tiles floor to 12” above worktop so I'd also like to run the cooker cable directly into the switch not via an outlet. Cable would go firstly sideways 8” behind the next unit then vertically 12” in conduit to the surface mounted box so neat, minimal risk of damage etc.
Changing CCU to switch sounds like-for-like and even in a kitchen I believe this is ok diy, no building control, thoughts please.
I’ve had the boards up to check the cable (well actually to add PIR cables) the 4mm T&E in good condition but it’s running in notched joists next to a 22mm gas pipe, no protection, yet! Any rules against gas, next to cables? Imagine nail into 30A circuit- lots of arcing & heat next to a gas pipe. Should I notch a fraction more and add steel conduit, I'm no where near 1/8 of the joist yet?
The 4mm terminates at a separate fuse mounted next to the main CU, no RCD’s anywhere, any simple & reliable options to improve safety?
Thanks in advance for any pointers..
