I've got a Howdens kitchen sat in my garage waiting to be fitted (by me....), I'm starting to plan the units.
The wall where I'll be attaching wall cabinets is a solid brick wall, I have attached 25mm battens with 350mm centers, onto which I intended to attach 12.5mm plasterboard (foil backing for insulation, 20mm foam between battens), but would this be adequate to attach 900mm tall wall cabinets to, or should I really use Ply as a backboard instead?
For me, the easiest solution is plasterboard, but would this be risky?
Appreciate your help!
