MCB Colour coding
4 Jan 2011
Is there a standard for colour coding different ratings, or is it each manufacturer to their own?
I'm trying to make some diagrams of a CU and I can't seem to determine which colour goes with what rating.
Does anyone know of any standards?
Or is it just a case of picking one manufacturer and sticking with their scheme?
No, different colour codes from different manufacturers. No standard as such.
The old type re-wireable and fused cartridges used to and some of the dollys on the MCBs were also coloured but in general they don't colour code the MCB. Wylex were good at this.
Something like this:
6a, colour white, MCB
10a, colour grey, MCB
16a, colour blue, MCB
20a, colour yellow, MCB
32a, colour red, MCB
40a, colour orange, MCB
Contactum MCB's
Kanlux, glued together using photoshop
Their 45A and 63A ones are black.
There isn't really a need for colour coding, is there?
Not really no, but, in my opinion, its a lot easier to see a colour and instantly know the rating of it, so if you see a "green" MCB you know it will most likely be powering a light circuit, and if you see a Red you know it will most likely be a dedicated circuit for a stand alone device exceeding 6KW. That kind of thing.
Just curious, that's all :)
Might try to make a table of different manufacturers for the wiki or something.
Thanks for your input all.
IMO it looks cack.
And how many householders will look at a green handles MCB and think "oh, that must be a lighting circuit".
Most of them just push "it" up if "it" is down.
You could argue that 3 phase installation colours don't matter which order they are in, as long as they can easily be seperately identified.
Yet it is written in standards that its L1 Brown L2 Black L3 Grey.
You could argue that potable water pipe doesn't need to be blue, or gas pipes don't need to be yellow, since they can have writing on the side what their use is.
It just makes life a little bit easier perhaps.
