Unusual Lockshield Valve sizing
5 Jun 2012
Lancashire
Hi all!
I need to change 6 lockshield valves in my house as they are damaged. I have a 10mm BSP copper pipe, so i went to my local plumbers merchants and purchased 6 standard 10mm lockshield valves. When i returned home to fit them the valve went on the copper pipe but the nut already on the copper pipe was to big for the valve. The valve and nut fitted the radiator end perfectly though
I took the valves back to the merchants along with the broken valve and was told they did not sell the fitting i require. I was told i needed a 3/8" valve or i need to cut the olive fitting that is already on the pipe on each of the 6 pipes (this is very time consuming for an amateur) The house is only 12 years old so i thought it would be pretty standard fittings (apparently not). I have searched the internet but cannot find what i require. Any help in finding the lockshield valve i require would be greatly appreciated. The photos above show the broken valve i require. Thanks
Different makes of 10mm valves will have different nuts
Cut the olive with a hacksaw and twist it if with a screwdriver it will take about 30 seconds
Just a little worried about going through the copper pipe and bending the pipe with screwdriver. Do these fittings exist?
Use a junior hacksaw and just be careful. You don't need to cut all the way through. Cut diagonal and break with screwdriver use ptfe tape to re seal
If it helps at all - the thread on the 10mm end of the valve looks like a coarse BSP brit. std. pipe.
PTS ( Plumbing Trade Supplies ) their Tradesave range - I`m 99.9% sure that`s the one :idea:
