Firstly, we have no idea, nor do we care whether kazzab is a young lady or a young gentlemen, nor whether kazzab has blond hair, black hair or no hair at all. Kazzab asked a question to which we tried to answer.
Secondly, no objections to some one posting again when they do not understand simple calculations
You seem to be concerned with the diagonals, but the diagonals are irrelevant and only required to ensure that angle C is 90 degrees. However to put your mind at peace the long diagonal should be 10965 and the short diagonal 8973.
Did you know how to work that out? If not, come back and we will explain.
We worked the metre square out by the length and average width to be 42.75ms, which is the easiest and quickest way
How ever lets do it a different way take the area of a rectangle 7.5x3.4 equals 25.5ms.
Take a triangle with an adjacent side of 4.6, opposite side of 7.5, hypotenuse of 8.793, angle A 58.48, angle B 31.52 angle C 90 Add the angles up and they come to 180 degrees and the area of the triangle is 17.25ms. With us so far. Good. Add 25.5 and 17.25 equals 42.75 ms same as above.
Will agree that we do not know whether long side and short side are parallel, but who cares if corner C is slightly out of square then you may need couple of barrows more or couple barrows less. No big deal
Goodnight, time for bed. oldun
