Hi, first time poster after some advice, please take it easy on me!
Right the situation is I live in a block of apartments with a communal boiler that comes on from 6.00am to 11.30pm everyday, in each apartment this is used to heat the radiators and hotwater. It’s an old system and the controls for the heating and hotwater no longer work in my flat leaving the radiators on all day, and very hot water. After searching on the internet it would seem my flat would be suited to a “s-plan”. The plumbing is straight forward enough but I’ve a few questions about the wiring, I would be grateful if any one has any advice.
Firstly, I don’t see the point in paying out for a programmable room thermostat, and would prefer the cheaper (money is tight) simple wireless room thermostat, seeing as the boiler is already on a timer and I pay a service charge which includes unlimited heating. If I do this am I right in connecting the live in (from a 3 amp plug) straight to the greys on the motorised valves? And the neutrals and earths all tighter in the wiring centre? As well as connecting the L,N&E in the wireless receiver straight in?
If so that leaves me with 2 wires from the heating motorised valves (Brown & Orange) am I right assuming that the orange is of no further use and can be connected into a spare terminal in the wiring centre? And that I should connect the Brown to the switch out from the wireless receiver (after connecting the wireless receiver into a permant live on the common)?
If I am right, then is it the same with the hotwater valve and the orange again has no further use, and that there should be a permenant live to the cylinder thermostat and the switch out that breaks on tempreture rise is connected to the Brown on the motorised valve?
I hope you’ve got your way through this long winded post and I’ve tried to be clear as I can, but would really appreciate any input and thoughts. Thanks again.
