Hi, I'm new to the forum, please excuse the essay and forgive me if this has been covered before, I have had a look around but couldn't locate the exact info I needed
I've signed up because although I have an electrical background and am familiar with domestic wiring, I'm no expert and I wanted to get some confirmation/feedback on a circuit I have planned to use in a family members chalet, he has completely gutted it and it is going to need an entirely new electrical system, and I'm trying to do it in the safest and most convenient way possible.
Basically, I will be fitting a dual rcd consumer unit to the incoming tails, aside from radial circuits for the cooker supply and shower he would like a few 2g sockets per room and a lighting circuit. Because the project is being done in stages I have ruled out a socket ring that covers the entire chalet because of having to delve back into completed rooms that have been boarded and furnished, also because of a lack of any kind of loft, I don't wish to fit junction boxes wired conventionally for his spot lighting circuits because they will later be inaccessible if there were to develop a fault, so my plan is as follows:
For basic rooms such as the lounge and bedroom where only a few sockets and a lighting circuit is required I intend to use a b32 and 2.5 flat t&e running a small ring of say 3 2g sockets, with 1.5mm flat t&e take a single 5 amp fused spur off one socket up to the dimmer for the lighting circuit. Because of the issue with lack of access for a rose/junction box I was going to join the earth and neutral inside the 1g dimmer box and obviously run the live in and out of the dimmer on the way up to a radial daisy chain of a maximum of 6 gu10 50w halogens.
What I'd like to know, is would this be acceptable practice? It allows me to keep each room totally independent and minimises the amount of cable used and keeps the circuits as simple as possible....
When it comes to the shower room there will be a b32/b40 10mm radial to the shower and a b6 with 1.5mm t&e to a double pole pullchord or wall switch outside running a light and fan, perhaps running a 3&e to the fan for run on.
The kitchen will be a ring with the same 5a spur setup for lighting as the other rooms.
So, I am open to any feedback and appreciate any criticisms of my plans, I came here for info and would like to end up doing this right
I'm also unsure on the regs as far as testing goes, it's a holiday residence but I'd imagine for safety and insurance purposes it would still need certifying?
Many thanks in advance, much appreciated
Dean.
Dean.
