Hi, I've recently moved into a house that has a Logic+ 30 combi boiler. It was fitted in Feb 2011.
I've noticed that there is a permanent flow of water to the boiler, with it using 0.02 cubic meters per hour.
The pressure is 1.2 bar.
The refill loop valves are closed.
I cannot see if there is water coming from the condensate drain or the safety run off as the pipes do not emerge outside.
Does anyone know what the problem is please?
If you need any more details, please let me know.
TIA,
Alan.
TIA,
Alan.
