Your PCB is fine!
Why do you suddenly want to change it now?
Tony
And do you have reason to believe that is is circulating the water effectively? For example, do all the radiators get uniformly hot within a few minutes?I think the pump is fine. It can switch easily between the 3 modes without hassle.
YesAnd do you have reason to believe that is is circulating the water effectively? For example, do all the radiators get uniformly hot within a few minutes?I think the pump is fine. It can switch easily between the 3 modes without hassle.
