Hi, I have recently bought a house with a 70% completed loft conversion by the previous owner. My question is how do I go about finding out if the conversion is done to building regs, should I get it inspected by the council or will I be opening a can of worms?
Surely your solicitor asked if the works to date had been done to Building Regs or not when you purchased even though it was never certified?
What has been done, are there some steels? Are they exposed? How much has been covered up? You'd typically expect a steel at floor level under each purlin and beefy floor joists. Got any of that? What about insulation?
Ideal you need what plans they previous worked to.
If BR applied they may be willing to give a copy.
You def need to know what the design/spec was because there is so many variants that you could be working to.Ie
Steel or no steels and where they are required floor roof or neither
insulation what was spec to meet requirements
fire guard, i had details changed on dormer wall
Phone building regs firstly, If they have nothing you'll need start from fresh but getting help to work out what you got is good enough and work from that so that when you carry out the completion BR can sign off the start to your application. ie your loft has wood no steels and your SE designs it with steel. BR might notice difference.
Hope that makes sence
