If you mean the 'square in square', mine doesn't but a very small wall wart camera charger does.
So your laptop charger probably has an IEC C14 or C6 inlet (or some other comparable connector)?
So it probably uses the earth for functional purposes.
Which is why it can't be classified as Class II.
The camera wallwart charger maybe has an ISOD (Insulated Shutter Opening Device - aka a plastic earth pin), and if so, is quite clear that the Class II mark is correct (although not all have plastic earth pins).
