Hi
This is my first post so hello!
I am planning on installing an oak floor on top of a suspended chip board floor, which I previously installed when we weren't sure what floor surface we would have. Potential considerations are:
- likely heavy use, so needs to be reasonably firm wearing
- very moist environment, due to sea in front and steep mountain behind the house
- we have a solid fuel rayburn (with a tiled hearth) but which gets very hot when in use, and generally coal dust can sometimes spread beyond the hearth
- currently stud walls have been installed ontop of the chipboard floor and transmission of sound from one side of the house to two rooms removed at the other side (~ 15m) is loud, and it'd be nice to reduce this
- lastly I am a musician, and the sound of the room is important to me. What I mean is that for example, with laminate flooring when playing the violin produces a reflected sound which is very tinny / metallic and of whihc you tire quickly. In contrast, friends of ours have a solid wood floor which produces a warm pleasant reflected sound which your ears don't tire of. Does that make sense? I don't know why laminate sounds like that, but I am worried that engineered wood, or perhaps heavily lacquered engineered wood might start to sound like laminate?!
So I am wondering what is best:
- solid wood or engineered wood
- with either, which surfacing is best: oil, uv-oil, trad varnish or lacquer
- whether I need some sort of underlay between the chipboard floor underneath and the floorboards on top
In particular, if there are any specific product recommendations I'd be very keen to hear about them!
Thanks in advance for your help.
Cheers,
Jamie
Cheers,
Jamie
