Son went over a pothole in his 51plate 106gti 16v , engine stopped ! He tried reset button , no luck. Car starts then cuts-out , checked most connections , cleaned all earths , looked for broken wires. Pulled fuel rail off - turn engine and you get about 3 spray's of fuel from all injectors , then stops. Fuel pressure seems ok , put thumb over return pipe! It has a 3 plug ECU , and a BROWN relay underneath. If you feed some fuel in via a small pipe into manifold , engine runs ! What is telling the ECU to stop signalling injectors?
p.s. Also put permanent 12v feed to pump, checked Crank pick-up , all fuses too. There is a 12v feed at injectors if you keep cranking , one lead on earth , thats why I thought it must be the ECU stopping the earth pulse.
Any help or advice would be great , I'am going nuts!
Mark 07798638388 anytime.
