N
NewFolder
I have a MEM Memera 3 Fuse Box (don't think it's classed as a CU, it has fuses inside).
It has 4 fuses in it: 5A for lighting, 15A for 'Heating' (I think it means immersion heater, I don't think a timer and pump will draw 15A), 30A for the ring main, and a 15A for the cooker outlet. The fuses are cartridges with fuse wire inside them.
There is a CU in the loft, with a RCD and two MCB's. One MCB supplies the electric shower, and the other supplies one double socket in the loft (AFAIK it doesn't supply anything else).
I'd like to know whether this setup is dangerous or it should be replaced. The house was built in 1985, and we've been living there since 2005, and in that time, we've only had to replace two fuses, once because some guy tried to replace some wall lights and wired them up wrong (idk how) and caused a short circuit. The second time was when a shed installer decided to try to disconnect and move the shed socket without asking us to switch off the electricity first. Fortunately, he managed to blow up the fuse instead of himself!
Might it be better to just keep the current system and perhaps use those plug in RCDs on certain appliances?
Am I correct in thinking that the fuses will protect against an electrical fire, but not necessarily electric shock, and RCDs will do both?
Does anyone know around how much it would cost to replace this fusebox with a modern consumer unit with MCBs and RCDs, bearing in mind that there are only 4 outputs?
If anyone needs any more information please ask.
