I had the gas for the cooker in my kitchen disconnected and capped this morning. Now I thought that as the pipe was capped 10cm from the tee of the gas pipe as it passes through to the lounge and the gas fire as is going to be stuck permanently behind a cupboard and inaccessible it should be capped with a soldered on cap. However it was done with just a compression cap. I did query it but he was insistent that a compression cap was fine.
Have I got this wrong and a compression is fine or should I get it redone with a soldered on cap?
