Hi Guys, brand new here, I need help please!
Okay. I have a cylinder in my bedroom, which is on the same level as the bathroom.
The hot water pressure is really bad, so I installed a single impeller booster pump ( with built in pressure switch ) to the outlet of the cylinder.
All it does is feed the hot water back into the tank above via the expansion pipe. Rather than boost the hot water pressure/flow. Should I have fit it to the cold inlet instead? Any help gratefully received! Thank you.
