Phone Line Extensions and ADSL not working
19 Apr 2009
Hampshire
Hello all, perhaps someone can give me an idea if I have missed anything.
Went away for the weekend all was working fine......
Come back, and internet is not working, did the normal rebooting router etc, still no effect, removed all devices plugged into the phone line. However Phone still works in the "extension sockets" . just not the ADSL BT line check shows fault within the property.
Removed all extensions (using the faceplate) plugged it in directly to master socket and it all now works correctly.
So it must be the internal wiring, so I removed the face plates along the wiring, and all look ok, I then split the wiring from the first extension socket, (so connecting master to second) this worked (from the master socket location). Joined the first, second, then third, together, and it stopped working, (the adsl). --- all extra devices have been removed from extension sockets
Got out the multi meter, and connected the wires at the end of the extensions - WB - BW / WO - OW / WG - GW (3rd extension its alot easier to get to), all of the connections are connected (ie completed circuit, and have the same resistance along its length give or take.)
Any ideas why? Next step for me is to swap out router, but I have never seen a router do this before.....
BT SOCKET --> Bedroom --> Kitchen --> 2nd Bedroom --> Living Room
---------------------- 1st --------- 2nd ------------ 3rd
Anything else to look for or guidance would be greatly appreciated.
Jason
I haven't, all the cables are chased into the walls, (sorry should have said that)
thats ok. even if they are in the walls, you can still test your wiring using new wiring.
I bought some from wickes, 15m for £4.97.
test it from socket to socket, like master to first, then first to second and if the problem is there, well eliminate the third etc, by jumping from first socket to third.
I am sure you know what you are doing, so forgive me (in advance).
Genius, Idea, - Will let you know
Jason
Glad I can help. I am doing some testing in my house, so on a steep learning curve.
I bought a IDC tool, if you haven't got one already, I got mine from amazon, delivered for £5 sold by amazon, free delivery, its by draper and works a treat.
ps...don't forget to click thanks
Well its sorted now, - for peoples future reference
Turns out from what i can gather, the loop attenuation on the line, and removing the ring bell wire, took it low enough for the router to connect.
All the cables where enacted, and ok, the other router did connect with the attenuation at 73.5, but the existing router with the bell wire removed dropped it to 70.5.
I can only presume the work they are doing further up the road has effected the routing of the BT line to give such increased attenuation.
Jason
Jason
Brilliant. I've just sorted out my wiring aswell, speed up by 4MB
Are you aware that due to the logarithmic nature of the dB scale, a decrease in attenuation of 3dB is a very significant difference? It actually represents a doubling of the power level on the line.
A typical reason for a gain of exactly 3dB in signal level is removing a 'double termination' from the line.
That double termination may be the result of using multiple master sockets on an installation instead of a single master socket / NTE, and fitting slave sockets elsewhere, or similar poor installation practise.
