Spur off unused cooker socket
Maybe not the situation, but as far as the percentage of the increased risk I would say it is.
You seem to be saying that having more sockets in itself increases risk. My view is that this isn't generally true - if risk increases, it's likely to be because of some change in usage, not because there are more sockets. I agree that one could assess an increased potential risk if an additional socket was located such that it was more likely to be used in a risky fashion (e.g. located such as likley to be used for outdoor equipment) - but I have been specifically excluding that situation in everything I've written.
If the socket was never used, does that mean it will offer no potential risk at all ever?
If it were literally never used (or 'touched') then that surely would be true - and any buried wire which represents a risk to someone with hammer and nails has always been there - so no change in risk. In terms of 'touching' (rather than 'using'), I supose that one additional non-RCD-protected socket theoretically increases the risk to children with screwdrivers/paperclips, or decorators, but I would imagine that the increase in risk would be extremely small (if there were already lots of similar sockets).
Whatever, as I wrote last night, despite all our discussion, the OP hasn't yet told us that the circuit isn't RCD protected - so the discussion may all be moot!
I have not checked yet if it is RCD protected, but what has been said makes total sense, all other sockets in the house are and if I am to make these into general use sockets, including the spur then I should ensure that it is RCD protected. If it is not, then I will get a sparky in to do the required work....
Many thanks for all the replies.....
If all the other sockets in your house are RCD protected, then that suggests that you probably have a CU which includes an RCD for at least some of the circuits. If that's the case, then its quite possible (although not by any means certain) that the old cooker circuit is also already protected.
Or if not, it may be possible to make it so by swapping sides, space allowing.
Indeed so. A photo of the board/CU (particularly with cover off) and the surroundings (in case there is a separate RCD) obviously could be very useful.
