If it's simply a voltage drop issue, you ought to have much the same problem if you tried it with just the garage chime (with its batteries!) - i.e with the front door one disconnected. As I asked before, does that work? It may, of course, be a combination of voltage drop in the cable and drop of voltage coming from batteries when loaded with two chimes - are the batteries fairly new?But now the problem is when the secondary chime without batteries is put into the garage, there doesn't seem to be enough power to work the chime, you can visibly see the mechanism move just a little but it looks like it doesn't have enough power to strick the chimes to make them sound. Probably due to some sort of voltage drop over the distance of the cable from front door to the garage. ... Any more ideas ?
