Open Vented pipework with no draindown?
30 Jan 2008
Yorkshire
I'm moving a couple of downstairs rads and also possibly changing some valves for TRVs on an open vented system. There are is no drain point that I can find and the pipework is below a wooden floor.
I'm wondering if I close the gatevalve on the CW out from the F&E tank and also cap the vent, will there be enough vacuum to allow me to work on the pipes/valves? Also probably closing off all the rads to isolate the water in them? I want to avoid a full draindown if at all possible since it looks like it's going to be a pain (there's no route to the outside below the floor to drain anything and I guess it's a bad idea to drain onto the earth subfloor).
I'm planning to get the new pipework ready with a pushfit to join new to old so it would be a matter of cutting through the old pipe and attaching new pipe with that pretty quickly.
You may obtain enough of a seal but if not bung the outlet of the F/E tank.
You can also isolate and remove the rad and then use the rad valve as a drain point.
If fitting new valves, then fit valves with integral drain cocks.
Arctic kits are not the choice of professionals.
Thanks, only problem with rad valve drainoffs is there's a lot of pipework below that level so it would still leave some water in the pipes, better than nothing though.
Oh, and I suppose I'd better mount the JB currently resting on the floor (thank's previous owner) elsewhere if there's a danger of water getting on the sub floor!
If you close the rad valves all you are draining is the pipework, perhaps 20 litres.
The best place for a drainoff is connected under the floor and going straight out through the wall to the outside if thats possible.
Tony
