Hi there,
i have a wooden drawer with a metal handle. The back of the metal handle is fimly fixed to the drawer. However, a small part of the handle has come off from the back plate causing, of course, the handle itself to come off.
I have tried fixing the small part onto the backplate using an apoxy resin but this didn't work. The drawer is heavy so a lot of pressure is put on this small part when the drawer is pulled open.
I have attached several images to help show you what I mean.
Can anyone recommend the best product to use to hold this handle firmly in place? It needs to be something incredibly strong as there is such a small area that can actually be fixed/glued. Remember as well, this is metal to metal.
Hope you can help!
Hope you can help!
04 - close up of part to be fixed/glued on
- gtrance
- 1
04 - close up showing the exact part that needs to fix into the backplate
