As the title, guess I tightened too hard.
Thing is the one radiator that sheared is different to all the other radiators in the house. The others all have a large bolt at the very side of the radiator with the bleed nipple in the middle. These appear to be the standard 1/2 " BSP valve which I've found online.
This has a much smaller bolt than the other radiators holding the bleed screw (an 11mm spanner fits it). Anyone any ideas what I'm looking for/where I can get one.
Next bit, if a replacement can be found I assume I close both radiator valves down undo the screw, catch water until it stops and screw in replacement (should it be available) with PTFE on the threads?
I've tried to add a picture of the radiator in case that helps.
All help appreciated.
