Help! Leaking power shower! :(
13 Nov 2012
Hi! I have a leaking triton power shower. When it's turned off water still cames out trough the shower head! What can it be and who do I need: plumber or electrician? Thank you to anybody for any info!
You got a faulty solenoid valve assembly or control valve depending on model & age of shower.
Have no idea how old is that thing, but older than 4 years, which I live in this flat. And nothing was removed or changed recently. Couple a days ago after shower I noticed, that even thou shower is turned off, water still coming.
Model is "Triton" . Nothing else on the box itself and inside I'm afraid to look
What should I do? Is it possible to fix or do I need new power shower? And who do I need : plumber? Sorry I'm useless in such things :)
Yes just buy the part and fit.
But if you going to get someone to fit it get a plumber or someone who knows about showers.
See many that have been attempted to be fixed by clueless plumbers/handyman and been a total c*ckup.
This is a easy fix by the right person.
Thank you so much for your help! I'll sleep better knowing that it won't cost me couple of hundred pounds :) Good luck to you in your not easy job
