    Dismiss Notice
Help! Leaking power shower! :(
Discussion in 'Plumbing and Central Heating' started by Natashazar, 13 Nov 2012.
  1. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
    Hi! I have a leaking triton power shower. When it's turned off water still cames out trough the shower head! What can it be and who do I need: plumber or electrician? Thank you to anybody for any info!
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    How old is the shower, have the covers been removed recently?
  4. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    You got a faulty solenoid valve assembly or control valve depending on model & age of shower.
  5. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
    Have no idea how old is that thing, but older than 4 years, which I live in this flat. And nothing was removed or changed recently. Couple a days ago after shower I noticed, that even thou shower is turned off, water still coming.
  6. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
    Model is "Triton" . Nothing else on the box itself and inside I'm afraid to look
  7. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    Give us a pic of the front.
  8. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
  9. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
  10. Sponsored Links
  11. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    When you turn it off does the pump stop and water keep flowing ?
  12. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
    Looks that way ( sounds )
  13. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
  14. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
    What should I do? Is it possible to fix or do I need new power shower? And who do I need : plumber? Sorry I'm useless in such things :)
  15. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    Yes just buy the part and fit.
    But if you going to get someone to fit it get a plumber or someone who knows about showers.
    See many that have been attempted to be fixed by clueless plumbers/handyman and been a total c*ckup.
    This is a easy fix by the right person.
  16. Natashazar
    Natashazar
    13 Nov 2012
    8
    Thanks Received:
    Country:
    Thank you so much for your help! I'll sleep better knowing that it won't cost me couple of hundred pounds :) Good luck to you in your not easy job
  17. calorific
    calorific
    22 Aug 2012
    1,466
    Thanks Received:
    66
    Manchester
    Country:
Loading...
Share This Page
