Double socket (metalcase & whiteplastic front) - earthin
6 Aug 2008
Lanarkshire
Would appreciate some advice.
I have a double socket in my shed which originally had a white plastic casing and white plastic socket facia/front.
The casing and front was damaged when the lawnmover fell on it and i have replaced with a new metal / steel casing and white plastic front.
I have ran the earth wire into the black earth point on the socket facia/front.
Is this correct? Or should i also run an additional earth wire from the earth socket to the metal casing?
Thanks in advance, Derek.
Yes, correct.
Although not actually a requirement if the screw makes good contact with the back-box in a fixed lug but it is considered good practice and will be safer.
Why on earth go for a metalclad box and still use a plastic socket?
Please don't say you've put one of these on the wall....
Thanks for the advice.
Ill run another wire just to be sure.
P.S. No i didnt buy one of those, although did consider as cheap as chips!! haha
