we have a Grant Euroflame 50/70 installed in our house. I'm not sure how old it is, but must be atleast 5 years as it was here when we moved in. It is currently installed sideways against a wall with the flue venting through the side panel hrizontally out through the cavity wall.
Due to the installation of a door in place of a current window, the flue is exactly 500mm from the door opening (regs state 600mm) which I'm not so bothered about as the door is hardly used when the boiler is likely to be on but TBH we don't want the boiler just inside the door. We therefore want to reposition the boiler within a few feet of current position. and change the flue position
Are there any Grant experts in the house that could tell me.....
If this boiler is compatible with the Grant ez-fit flue systems? (the current flue is rectangular where it exits the boiler, as is the stainless rectangular vent on the outside)
Are there any requirements regarding clearance of the boiler from a wall, either rear or side? ie could it be put right into a corner of room against the walls. The flue exit would probably be from the top and routed to a suitable position once moved.
If run internally, can flue be boxed in? any special material requirements?
Are there any regulatory requirements on access etc for servicing of the boiler? (ie access through front and top panels) or is it just a 'sensible' access
Does the boiler require any ventilation? ie can the boiler be boxed in, obviously allowing service access by mean of removable panels or similar.
Ideally the boiler will be located in a small toilet/cloakroom. Aside from the electrical zones for the spur switch regarding distance from water etc, does the boiler itself have any requirements?
And finally, one of the positions we have in mind would overlap where a soil pipe exits through a concrete floor. To avoid having to move the soil pipe Are there any rules/regs/recommendations regarding raising the boiler approx 6inches from the floor level some how (bricks/blocks?) to allow room for a soil pipe elbow? or would this be a none starter.
Please note, I don't plan to do any of this myself, but want a good idea of what can and cant be done before I get quotes for having it done.
many thanks
many thanks
