Hello, I'm new here but would appreciate a bit of advice.
I would like to install a range belling db49ei cooker, hob is total 7.5kw, ovens are total of 4.1kw and grill is 1.8 kw. One of the ovens can be used as a grill so I calculated the maximum possible at any one time would be 14.1kw.
The handbook firstly recommends a 10 mm cable from fuse board to cooker isolator unit, then 6mm to the actual Range unit. Later, however, it says to use a 10mm cable all the way. It also says to use a 45a fuse.
The cable run from the fuse board is about 12m.
What size cable/mcb should there be in place?
