Dodgy lighting spur
30 Jan 2008
Yorkshire
I've been decorating which has lead me to discover some more wonderful electrics in our home. 2 metal Wall lights either side of the bed spurred from a ring socket and switched with 2 2way 2 gang metal switches.
The lights and switches weren't earthed so I've changed the switches over to plastic and managed to recover 1 cut back earth from an existing cable plus run a new earth down to a socket on the same ring below the other light (the 2 3 core cables running between them don't seem to have earths in them) so now the lights are both earthed.
Not ideal but leaves 1 remaining problem, they have been spurred off the 2.5mm main using 1 or at best 1.5mm cable without being fused down. Having just decorated I'd prefer not to have to install a FSU in a new hole in the wall and/or damage the decoration attempting to run new cable (the 3 cores run in plastic surface trunking along the skirting board but it looks like they had fun getting them through a stud in the wall).
What options are left? I had wondered if there was such a thing as an inline fuse that I could put in the back of the socket but it seems they are not very common and probably not meant for this purpose. I had thought of running cable upto the loft above and back down to get rid of the surface trunking but that involves a lot of work too (it's fully boarded).
I guess the risk is that the lighting cable could be overloaded but how likely is that in reality? Must have been like this for 20 years. I see in a recent thread that there was a spur in smaller cable that wasn't fused down that got a C3 which I assume is livable?
I think that reference to a C3 was sarcastic, can't be sure though.
What about a surface mounted FCU under the bed? Minimal disruption and if it's under the bed it's not the end of the world that's it not flush
Thanks, I might look into breaking into the wall from the room at the other side, at least that's only painted not papered. Then I can run the cables properly and replace them at the same time.
You mentioned a stud in the wall? Does that mean it's plasterboard - in which case cutting it open to insert an FCU needn't disrupt your decoration. If it's a stud for lath and plaster it's a different matter of course ...
pj
pj
Yes just PB but thinking longer term I'd like to get rid of the surface trunking for the 3 core so going in behind to deal with any studs in the way may help with running replacement cable.
If that was my post, yes it was sarcastic! Perhaps I should change it invade people get the wrong idea and think having 1mm off the bring is perfectly fine.
