Hi, I recently moved house and had a new 40kw Bosch condensing Boiler fitted and the system flushed but the two furthest radiators in the system dont seem to give out enough heat or as much as all the others.( our living room)
There are 20 double convectors and 3 heated towel rails.
Pipe work is 22mm with 15mm to radiators.
Tried balancing the system and feel I either need to fit a couple of higher output radiators or a better circ pump ( room is approx 38m2), current ones are approx 1800 watts each with a delta T of 50 deg C.
Circ pump is a British Gas Multhead G. Radiators outer temp is approx 59 to 62 deg C. TRVs are fitted on all except three radiators.
I am considering high output aluminium radiators.
Any suggestions most welcome. House is cavity wall insulated, suspended wooden floors with UPVC double glazing throughout.Built in 1988.
many thanks
Andy
many thanks
Andy
