Hi all. Just need some clarification as its been a long time since I did electrical engineering.
I am building five independent china balls (lanterns) attached to flex and a dimmer on each. Plug>Dimmer>Lamp socket>100W bulb. As you may know it is common for films to utilise china lanterns on film sets as a way to get good soft light, cheap.
I have the appropriate size lantern for a 100W bulb as well as a standard bulb socket that will take 100W bulb.
Firstly, I happen to have 25m of 3G 1.00mm2 flex but I understand this is overkill for what I am doing, but does this affect anything? Should I just go and buy some 2G 0.5mm2?
I don't need to earth it do I? Generally lamps/lights are not earthed are they!?
Can I just swap out the 13A fuses I have in my standard plugs and replace them with 3A?
Thanks in advance for your thoughts and expertise. Just being safety conscious.
