hi helpers, I have a fairly new drayton mid point actuator code MA1
occasionaly it dont click over to heating it will either stay in mid or water position. to get it to move I use programmer to put the hot water on then turn that off then put the heating on then it moves or I can gently move the switch over to H on the actuator so would a club hammer fix it
another strange thing is I have a salus RT300RF receiver wired into Drayton dual channel programmer. the green light on the receiver never seems to go out ? it says in the book " the LED ( green ) illuminates when the receiver unit is receiving a heat call transmission"....
if I lower the temp a few degrees on the thermostat the green light does go out but otherwise the green light stays on even when the heating is off for the night so over to you guys Thanks P M
