Toilet Seat Problem
  • Thread starter Thread starter Shutpa
  • Start date Start date
S
Shutpa
Got a QX Urban toilet and cistern fitted a few months ago and the seat has started sliding about. Problem is that the pan sides are totally verticle so that the usual tightening nuts are just not there. It would appear that in order to tighten the seat uip, the whole toilet pan would have to be dismantled. Am I right or is there an easy way to sort out this problem? :?: :?:
Post a picture of the seat hinges with the seat up, normally the hinges can be tighten up.
Andy
Some of these toilet seats are fixed from the the top. Check by lifting/moving the hinge covers and tightening from there just in case.
Usually you can lift off the decorative cover and find a screw head to tighten, hopefully the spring toggle nut will grip without having to slide wc forward.
Al
This ok? It is the one on the right that appears to be slackening.
Slide off the toilet seat/remove pins. Lift up the chrome covers and re-tighten the screws that go into the pan. Refit chrome covers and seat.
Andy
you normally push the two chrome buttons in that you can see & lift the seat straight up
you normally push the two chrome buttons in that you can see & lift the seat straight up off of the pins, lift up the cover & tighten then just click the seat back on
It is manufactured by a Chinese-owned (HKR Ltd) Australian company (Imperial) in an ex Ideal Standard factory in Middlewitch - Ours Sanitaryware. 01606 830 271
Well done mate!!!!!!!!!!! Seat back to normal - wife happy - and brownie points galore!!!!!!!!!! :D :D :D. And thanks for the full instructions in your folow-up post.
