I have a mira 9.5kw shower fitted.......had problems with it and as I had no confidence in the plumber and leccy that fitted it(had many problems with them) I rang mira and they sent an engineer out to it.....appeared that it had not been fitted to the wall correctly and the guy said that the cable supplying the shower was only 6mm and not enough for a 9.5kw shower(before I bought the shower I asked the leccy what size shower I could go upto) the engineer also said the fuse for the shower should be 47amp. The shower keeps tripping....can I just get an 8.5kw shower and fit that instead? Your help would be much appreciated!
