I would appreciate some advice on earth requirements for a new timber garage and separate workshop which will soon be erected. An existing two core armoured cable wired from the freshly rewired house will supply new supply boxes with 30mA RCD & 16 and 6 Amp MCB,s in each outbuilding. An underground junction box will split the supply to each building. I believe the house has an earth terminating next to the meter and this is common practice these days? The armoured cable is joined to the MCB controlled supply behind a blank in the kitchen wall and then goes straight outside and then underground. I don`t know if the armouring is earthed - or should be?? In the outbuildings, should I fit an earth spike and earth wires to the supply boxes??
Hope I`ve made things clear - ask away if I haven`t!
Many thanks in advance!!
