Hot water issues
...The temperature of the water entering the boiler is lower - hence the temperature differential is greater. Schoolboy physics. :roll:
Differential may be greater, but that has nothing to do with efficiency.
Maybe you don't quite understand the difference between efficiency and efficacy.
Checking that the boiler is on maximum hot water settings in winter is good advice. Many people don't realise that a boiler is less efficient in winter than summer. Sadly, you are one of them. :roll:
I didn't realise a boiler was less efficient in winter.
Can you tell me why that is please.
I may be daft here but what's that got to do with efficiency?
Yes you are daft. Efficiency doesn't come into the equation at this point.
Which bit of that do you disagree with? As a device a boiler is less efficient at producing hot water in winter than summer. Just as a kettle full of cold water takes longer to heat than a kettle of warm water.
That bit. A boiler is as efficient in summer as it is in winter, unless you bother to look at the bits behind the dot e.g. a steamer rated as 91% will never be less than 90% and never more than 92% efficient, regardless of whether it is -20 or +40.
edit
In fact, if were to look at the bit behind the dot, a steamer is a fraction of a percent MORE efficient in winter than in summer. Not measurable outside a lab, but if you insist on splitting hairs.....
Yes that bit plus the bit about me been daft
Has anyone seen the OP who started this thread?
I was wondering if we had answered his question satisfactorily?
