Sort-of, but extremely belatedly - Schedule 4 (and, before it Schedual 2 or whatever it was called) has always had 'provision of a CU' as one of the exceptions to exemptions from notification - so I could probably actually have asked a similar question at any point in the past several years!You've been thinking again, haven't you?As we know, come April 6th, one of the few things still notifiable will be 'provision of a new consumer unit'. Given that BS7671 clearly defines a 'Consumer Unit' as being a type-tested DB, does this mean that provision (and installation) of a new non-type-tested DB would be non-notifiable?![]()
The BS7671 definition of CU seems to indicate that it means that the entire unit, factory-populated with recommened components, has been tested. If that's the case, one way to make sure it wasn't 'type-tested' would presumably be to use a 'bare' (empty) CU enclosure and populate it with contents which were not 'recomemnded' (i,e. a different make.What exactly does 'type' mean in this respect?
I'm afraid that your guess is as good as mine. We all understand the intended spirit of the Building Regs - but it just occurred to me that there could be a theoretical loophole (for those interested in such things) in the actual words of one of the few notifiable jobs that will remain after April 5th....So if two manufactures have used the same standard to design their products does that mean the parts may be interchangeable? (Obviously they would have to fit) It probably wouldn't be worth the bother of finding out if all properties were the same but if 'type' merely refers to 'consumer units' rather than Hager are one 'type' and MK are another 'type'. .... I know it looks rough and unsightly so don't/won't do it but just wondered.
If thinking about 'new circuits' came up trumps, then self-certifying electricians would perhaps have to be renamed "Shower fitters"
One would obviously first have to research what is regarded as an 'accepted definition' of"Consumer Unit" (hence also "type-tested") - but if those definitions were favourable to one's argument, BC and the Judge might find their hands tied!Wouldn't fancy anyone's chances trying to argue that one with building control ..... or the judge![]()
I can't tell you who accepts it, but per BS7671 (i.e. 'the regs') a circuit is "An assembly of electrical equipment supplied from the same origin and protected by the same protective device(s)". At face value, that corresponds with what we would all say - i.e. one MCB/RCBO in a CU (or occasionally other origins) equals one circuit. A 'new circuit' would therefore be one run from a new protective device (MCB/RCBO/Whatever) - again, corresponding to 'common sense'. Whether that leaves any loopholes requires a little thoughtWhat is the accepted definition of a new circuit?
