Hi guys,
The isolation valve up in the loft is weaping (from the flat head screw)
It's a compression fitting.
My question is, can I just replace it with the appropriate sized handle valve? (It's a 22mm)
More specifically, can I re-use the existing nuts on the pipework and just screw them into the new valve or must I remove the old olives and use the ones that come with the new valve?
(Have uploaded a pic if it helps?)
Thanks for any help.
View media item 56575
