Bernardgreen electronics.Q
25 Feb 2009
Essex
You're the man bernard.
I've got a component that even the electronics forums don't recognise.
I don't get it.
Any chance you could give me two minutes of your time.?????
Resistor bands are.......brown -black- silver-brown -black.
Its a fusible resistor in my book. Never seen anything like it though.
It's from a power supply board.
Research tells me the chinese put the last black stripe as an indication of it being fusible.
Since then i've been told it's an indication of the temp coefficient.
No-one seems to know.
Can you save me pulling more of my barnet out????
And why are there different resistor scales for banding.????
The worlds gone mad.
I would appreciate your help.
From the web
http://itll.colorado.edu/index.php/electronics_center/resistor_chart/
As to how a fusible resistor is marked ? The only time I have had to design in fusible resistors they have been selected by manufacturer and type and clearly documented as being fusible, often with text in the board screen print. I would not have been allowed to rely on the colour coding as other than value and tolerance the other bands used differently by different manufacturers. Replacing a fusible resistor with anything other than the exact same type can negate the function of the resistor.
Thanks for the reply Bernard. I mean that.
You were my last hope.
I'll bin it.
I appreciate your time.
From the web
Btw....silver as a multiplier (according to your link,and many others) doesn't come into your scale ......that's what I was trying to say/ask.
Silver as third band strongly suggests the coding is not a resistance value coding, instead it could be a manufacturer's type number / part number.
The poster in the link isn't me.... But he has the same sort of point.
Look at the scale three posts down.
Silver now has a non tolerance value and has become a minus multiplier.????
This is my dilemma bernard.
According to the link i provided, the value of my resistor is 0.1 ohms, 1% tolerance and 250ppm.
RS and Farnells don't stock 'em. No such thing.
It's a mystery......
No one knows the answer.
Worlds gone mad.
Can you [a] post a picture and/or reverse engineer to create a circuit diagram of the part where this component is fitted.
