- Joined
- 27 Nov 2012
- Messages
- 8
- Reaction score
- 0
- Country
Hi
I'm planning my kitchen under cabinet lighting. I will have three wall cabinets in the kitchen, all apart from each other. About 10 feet between two of them and another 8 feet to the third, which is the other side of the doorway. I plan to chase the switch cable up the wall and into the eaves where all the connections will be made.
In order to run the cables to the relevant under counter lights, ideally I'd like to chase the cables into the plaster so you don't see them. However if I was to chase the cables down the wall to the relevant wall cabinet, how do you 'access' them if that makes sense! Obviously cable into a light switch or a socket emerges into a metal back box or similar, but with this situation there won't be any such box, I just want them to 'come out' from the wall and then wire into the light. I was trying to make sense of the rules and i'm not sure that you can do this? Also how do you make it look neat?
The alternative seems to be some sort of mini trunking, which obviously will show. How else could I do it?
The 10 ft distance between the cabinets is fairly simple, I was thinking of running some trunking between the two (behind the base units just above skirting board level so you wouldn't see it).
