Recap: I'm having an extension built with new boiler and complete re-plumb. I was slightly worried about the competence of the builder-appointed plumber. I asked for advice here and subsequently became very worried. Eventually the plumber was kicked off. He is Gas Safe registered for boilers, but no evidence has been forthcoming that he has any unvented qualification. Building Control were not advised that an unqualified person was installing an unvented cylinder.
The full detail (all 20 pages of it) is in a thread at http://www.diynot.com/forums/plumbing/worried-about-my-plumbers-competence.355290/
The builder has appointed a new plumber (who I am told is qualified for gas boilers and unvented cylinders, though I haven't seen first-hand evidence of that yet because I haven't been to the house yet).
I appointed a different plumber (with no links to the builder) to inspect and tell me what he thinks needs changing.
Gas Safe came out and inspected yesterday, but I haven't had a report from them yet. The builder says the inspector only looked at gas stuff (not the unvented) and was basically happy.
There is general agreement between the two plumbers about what needs changing, and the builders new plumber is taking the view that he's not going to work with the spaghetti in the cylinder cupboard - he's going to take a good proportion of it out and redo it.
However, one aspect of disagreement is that the flow and return between boiler and cylinder cupboard are currently 22mm, with a length of about 8m each way and seven 90 degree bends and elbows (each way) en route. The boiler is a WB 30 kW GREENSTAR 30 CDi CLASSIC SYSTEM' on natural gas. It is in a two-heating-zone plus hot water setup. It does not have the optional internal diverter valve.
My plumber is saying the pipework should be 28mm. The builder says his plumber says 22mm is OK. I am nervous of the fact that the builder really really doesn't want to lift the floors and take out the bits of wall that would be necessary to replace this run of pipes, not least because that's in a room that's finished (and decorated) and the making good will not be trivial or cheap. He may well be pressuring his plumber to say it's OK.
Can anyone advise their opinion of pipe sizes? The WB installation manual doesn't seem to say anything on the topic, though I note the pipes coming out of the boiler are 22mm
