Here we go again I'm afraid. I have to fit a new washroom basin and the modern style chrome bottle trap comes with it's own section of chromed metal pipe to take it into the wall. Standard stuff! Luckily I can fit it straight inline with the existing soil pipe fitting, but it isn't quite long enough to fit in one hit. So I will have to fit a short length of plastic 32mm pipe into the soil pipe connection with a compression connector hard up against it between the 2.
Everything is ok so far except, measuring the metal pipe supplied, it is that mystical 36mm OD. Oh yes it is, look at the photo!
The picture isn't brilliant but it is clear enough, that looks very like 35-36mm to me! I have seen many posts which deny the existence of anything close to 36mm sized pipe, and I take the word of professional plumbers who say it should be 32mm ID sized, except it is 36mm OD!!! It would seem sensible to assume that it is an equivalent to 32mm ID polypipe, does that seem sensible? So the compressiion connector I need will presumably be 1 1/4" or 32mm?
Has anyone else been down this route and is able to confirm that the sizes will match up here?
