The one that goes round a corner on to the adjacent wall looked classy to me.
I don't like the "dog legs" bends where the cables go across the wall then up or down. They should be in a straight vertical / horizontal run to the socket / switchplate.
If you look at the picture Chris5 posted then you don't need to know much about electrical installation to spot the errors.
If he's done work like this then you would wonder what else has been done that isn't visible and whether you should employ him at all without someone to supervise him.
Get the guy back, ask him to tidy up, show him a copy of the diagram I posted, suggest group factor is better and also suggest he goes and hires a wet cutter and goes in to the brick where cable bulging might interfere with the plastering line.
Have you any idea how the surface is being finished, is it being rendered / bonded and then plastered or boarded and skimmed? If boarded, will the boards have insulation on them, or plan boards and dot dab fixed?
The reason I ask is that the finished wall construction dictates the available profile for the cables on or in the wall.
The worse that could happen, potential for injury due to zones not being adhered to and what would be a false completion cert since lying about being in scope of the regs isn't a pass.
Also, isn't it true that the safe zone only exists for the cables associated with the accessory so once plastered no one will have any reason to expect cables to the side or below.
