Screwing plywood to floorboards - screws not going flush
the screws i suggested above should sort the problem
once they strip the thread [go round and round]the screw will never countersink or do any good
That makes sense, I'll pick some up asap and hopefully that will resolve the problem. Appreciate your help, many thanks.
just been out and screwed 3 off the screws i suggested into 6mm ply and 21mm pine
crisp clean easily screws self countersunk no hint off striping  8)
as an aside you need a pz2 bit not a ph2
That's really helpful, thanks.
OP; 3/4" screws are a bit short and will not bite well=enough into the sub-floor material. Try longer screws - say 1" or 30mm - there will then be enough threard to bite into the subfloor and pull tight down on the ply, possibly without even countersinking.
you got here in the end :D :wink:
Just to say I've been to Srewfix this morning (I found out there was one about five minutes from my front door that I didn't know about) and bought everything as suggested and the screws are flying in! The most fun I've had in ages!
Really appreciate the advice from everyone and your patience with such a novice.
Just got to lay the vinyl now! I'll leave that till next weekend I think...
