i was trying to fit a new light fitting and sucessfully wired the earth and live wires together, pop sound from somewhere, changed fuse in main board, rewired old rose back in and have no power in half my upstairs lights and bathroom fan, help
You have got a wire wrong in your terminals. WITH THE POWER OFF locate the switch wires(you should have a red/brown and a black/blue, put the other lives together along with the red/brown switch wire and the black/blue switch wire to the brown of the new light. put the other black/brown wires in the other terminal along with the blue from the new fitting.
Sounds like you've got a loop-in system and not looped in the power to the rest of the lamps.
Have a look at the stickies for wiring on this site and compare with your own wiring. You should have L, N (and perhaps earth) going into and out of the rose. From the L will be a wire to the switch. There will be a wire coming back from the switch. This latter wire goes to its own connecting point and into that copper block the flex from the fitting is a connected. The other wire in the flex is connected to the copper block with the neutrals. Earth connects as L and N if present and to fitting if required (must be if metal fitting).[/b][/u]
My guess is that the pop you heard wasn't the fuse going.
I don't think you should try fault-finding yourself, quite frankly if you are the sort of person who connects live and earth together you are the sort of person who should get an electrician.
is there an easy way to find the fault
....., wired old rose back as it was to start....
