- Joined
- 11 Oct 2011
- Messages
- 5
- Reaction score
- 0
- Country
I own a B&B and am about to fit 2 new shower mixer taps to 2 of our bathrooms. the 22mm gravity fed hot and cold supplies do not have isolator valves fitted so I will fit them when I drain down system and fit the mixer taps.
I need some reliable decent quality FULL BORE 22mm isolator valves so the water pressure which is already low is not further effected.
I was going to buy some from screwfix but then read the very poor reviews.
I cannot afford to fit valves that may leak or fail as the jobs got to be done very quickly and properly on 1st attempt as the room is in constant use and I dont needs leaks into the guest room below.
WHO CAN RECOMEND A DECENT SUPPLIER / MAKE OF RELIABLE 22MM FULL BORE ISOLATOR VALVES. THANK YOU
