Ah, I was tempted by their no-name stop ends at the weekend but the reviews put me right off. I stick with Hep2O and it's been good to me..apart from the pricetag.
I find this no-brand material of good quality. Actually the connectors have a clever design where the metal spring (that keeps the pipe in place) is behind the o-ring (and not in front), so the spring doesn't score/mark the pipe where the o-ring will sit. I have seen other brands and the order of o-ring and metal blades/spring is reversed, so the pipe can get micro scratches.
I've been aware of angles reducing flow for a while but I recently redid a kitchen where the predecessor didn't own a pipe bender so the pipework resembled a rubics cube (they'd litterally created squares of pipework to eventually get it pointing the way they wanted) .There was a minimum of 12 angles used between stop tap and kitchen tap - I ripped it all out and now there are 2 angles (one on each h/c)and only pipe bends...I'm still getting used to the new found water pressure/flow! It was an amazing difference, previously hot water took ages to get there and was sporadic.
Interesting. I have 6 angles along the line that brings the water to the garden tap and the pipe is 15mm. I wonder if the pressure washer would work much better if I remove those angles.
That's like saying the speedlimits been changed to 50mph an hour I may aswell just do 40mph everywhere (which some people admittedly do!). On branded kit I've seen the inserts restrict diameter about 10% a normal isolation valve would restrict a FURTHER 10% (minimum).
Ahah - good point. My point was: if you have 10% diameter reduction at any point of your line and you add another 10% reduction along the line, will the pressure/flow be further reduced?
I use full-bore valves where I isolate flow to a segment of the house
Makes sense.
