- Joined
- 1 Mar 2005
- Messages
- 75
- Reaction score
- 0
- Country
I'm after some advice on rejigging my garden.
The garden I've acquired is a concrete and slab jungle. I have a little one so I want to put down some turf for the good weather. I also want to keep a paved seated area.
It currently looks like this:
There's a wooden garage at the bottom. I've already been told on here that I can't put any new slabs tight up against the wooden garage. (thanks to FMT)
I plan on removing a load of the slabs but keeping a square area in the back (sunny) corner like this:
This will mean building up the existing concrete path to the same height as the slabbed area. There's about a 110mm step so I was planning on laying 2 layers of the 50mm slabs lifted from the other bit to level it off.
On this remaining square of old slabs I would then lay some new fancy slabs in the middle surrounded by some fancy decorative chips to look like this:
(not necessarily with the silly colours available in my CAD program).
The existing slabs & concrete have been done properly. There is 4" of hardcore and sand below them so I'm reckoning they are a good base to lay this new patio bit on rather than dig it all up.
Questions I have are:
Should the built up slabs be cemented in?
I'm not sure what, if any edging I need? I've read conflicting posts on here. I'll need something to retain the chips at least I guess.
Should the new slabs be put down on a bed of mortar and pointed?
Is the above idea stupid?
Thanks in advance for any advice.
If I get a response I'll post before and after pictures. (If anybody GAF )
