- Joined
- 20 Apr 2013
- Messages
- 2
- Reaction score
- 0
- Country
Hey guys just wondering what your quote would be for the following work. which iv already had done. Just wondering if he is trying to rip me off thanks
Its a semi detached 1930s house, brick walls with floor boards.Keep in mind i left existing wiring in place and added to this. And provided all materials myself. Also no one living here at time of work
Room one, includes 3 double sockets, 2 wall lights and one ceiling rose, 1 light switch. work commenced :
- Moving one double socket a meter to the left
- adding a new double socket to 2 meters to the left of the ^ socket.
- installing 2 wall lights to existing wiring
- renewing ceiling rose
- installing 3 double socket fronts (varilights)
- renewing light switch
Room two, includes 10 downlights mains. work commenced :
- connecting the 10 downlights to existing wiring, from above (already installed into position with wiring)
Room three, includes electric cooker socket, induction hob socket, 12 downlights mains, 2 double sockets. work commenced:
- running 12 meters of 10mm cable from CU to kitchen.
- knocking out holes for induction hob socket 45a and cooker socket 45a. 2 double sockets.
- installing fronts for cooking sockets.
- running cable for 12 downlights (before ceiling was (plaster boarded) and installing and connecting. (holes already drilled)
Room four, includes one ceiling rose, one single socket
- installing single socket front
Room five, includes 2 double sockets, ceiling rose, light switch
- moving double socket from wall to plaster board one meter to left
- moving double socket meter to left
- renewing ceiling rose and light switch
- installing 2 double socket fronts
Room six, includes 3 double sockets 1 ceiling rose, 1 light switch
- moving double one double socket half meter to the right
- renewing light switch and ceiling rose
Room seven, includes 1 light switch, 1 ceiling rose
Room eight, 2 light switches, one single socket
- knocking out for one light switch
- installing two light switchs
- knocking for single socket and installation
Room nine, bathroom light
- installing bathroom light
Extra work.
- running 8 meters of 1.5mm cable from CU to loft to separate upstairs and down stairs lights
- checking over existing junction boxes and renewing
- runnnng 2 lengths of 12 meter 2.5mm under floor from CU
- renewing light fiiting outside the front door
- fitting 2 outside lights
- fitting spot light to outside
- fitting double outside socket
- fitting new CU unit
- renewing main live an neutral fuse
Extra work.
