Hey guys, what wuld you charge for this work?
20 Apr 2013
Hey guys just wondering what your quote would be for the following work. which iv already had done. Just wondering if he is trying to rip me off thanks
Its a semi detached 1930s house, brick walls with floor boards.Keep in mind i left existing wiring in place and added to this. And provided all materials myself. Also no one living here at time of work
Room one, includes 3 double sockets, 2 wall lights and one ceiling rose, 1 light switch. work commenced :
- Moving one double socket a meter to the left
- adding a new double socket to 2 meters to the left of the ^ socket.
- installing 2 wall lights to existing wiring
- renewing ceiling rose
- installing 3 double socket fronts (varilights)
- renewing light switch
Room two, includes 10 downlights mains. work commenced :
- connecting the 10 downlights to existing wiring, from above (already installed into position with wiring)
Room three, includes electric cooker socket, induction hob socket, 12 downlights mains, 2 double sockets. work commenced:
- running 12 meters of 10mm cable from CU to kitchen.
- knocking out holes for induction hob socket 45a and cooker socket 45a. 2 double sockets.
- installing fronts for cooking sockets.
- running cable for 12 downlights (before ceiling was (plaster boarded) and installing and connecting. (holes already drilled)
Room four, includes one ceiling rose, one single socket
- installing single socket front
Room five, includes 2 double sockets, ceiling rose, light switch
- moving double socket from wall to plaster board one meter to left
- moving double socket meter to left
- renewing ceiling rose and light switch
- installing 2 double socket fronts
Room six, includes 3 double sockets 1 ceiling rose, 1 light switch
- moving double one double socket half meter to the right
- renewing light switch and ceiling rose
Room seven, includes 1 light switch, 1 ceiling rose
Room eight, 2 light switches, one single socket
- knocking out for one light switch
- installing two light switchs
- knocking for single socket and installation
Room nine, bathroom light
- installing bathroom light
Extra work.
- running 8 meters of 1.5mm cable from CU to loft to separate upstairs and down stairs lights
- checking over existing junction boxes and renewing
- runnnng 2 lengths of 12 meter 2.5mm under floor from CU
- renewing light fiiting outside the front door
- fitting 2 outside lights
- fitting spot light to outside
- fitting double outside socket
- fitting new CU unit
- renewing main live an neutral fuse
Can't see it no chance of being able to quote it (cue crystal ball pic?), but did you not agree a price beforehand or hourly rate?
At london rates the price seems ok. Probably too expensive in the north east but it's impossible to say without seeing the job.
If he has done the job properly, seemingly simple things like
is labour intensive as teh cables have to be removed from the existing position and new chses done up or down to the new position. Cable then needs extending, or re-run from the previos socket in the ring.
Some pictures would be nice (we like pictures)
Yeah I was going to say 'move one socket a meter to the left' could be done in one of a few ways, so more costly than others....
But ultimatly, assuming you didnt get a fixed price qoute, while you can try negiating a discount, ultimatly if the work has been done, you now need to pay them!
Daniel
Well that's one good way to make sure you get charged more for labour.
It ought to be quite simple for people to grasp.
Your electrician has worked out that he needs to earn X from a job like that.
If X = Y (markup on materials + Z (labour), what do you think he will do if you deny him Y?
Will he
a) Put up with earning less, and just tell the family that they won't be eating much next week?
or
b) Simply increase Z to compensate?
