Hi Joe,
I can confirm its dry rot, sepals lacrymans. When I took off the vinyl on the floor, I can almost see the joists, the wood seems flaky, loose, moist, holes in it. The dehumidifier, will it be permanent or just left running for a few days.
With the plaster, theres wood in the bathroom, the panels and they have a bit of moisture as well, it has a old wooded cupboard in the bathroom which I will remove as wood and water/high moisture area isn't a good mix.
I can also confirm historical water leak in the bathroom as well, this would have also had a major effect as well. There is also a problem with the rain water roof pipe, this will also be changed as this caused damp problems with the rear room. I will also fit a new fan extractor in the bathroom, maybe 2 even. What do you think ?
Thanks in advance
Thanks in advance
